first mig weld
  1. paulo1974 Member
    152
    porto
    hello
    i tried my first mig weld and it didn´t please me. can it be reverse polarity? torch (+) earth (-)
    setup
    Machine : 140amp mig welder (transformer)
    amperage the 2 more powerfull (1+max)
    Gas: c02
    Wire: 0.6 steel
    wire speed 7 from 10 possibles
    [​IMG]
    [​IMG]
    [​IMG]
  2. gordon stephenson
    gordon stephenson Forum Supporter
    6,857
    Skelton in Cleveland U.K.
    Somebody more experience with your type machine will be along soon, Grind your metal to have a nice clean weld area.
    123hotchef likes this.
  3. pedrobedro
    pedrobedro Man at Matalan
    10,459
    CX Derbyshire
    2+max would be the high setting on that. Clean it back to shiny metal and practise before you try again. Get some .8 wire as well. Torch positive should be good with co2. Get the torch in closer and hold it steady with your spare hand as you move forward.
  4. gordon stephenson
    6,857
    Also make sure that you have the work/earth return clamp on to bright shiny metal,
    ajlelectronics and 123hotchef like this.
  5. slim_boy_fat
    slim_boy_fat Forum Supporter
    Are you able to see the workpiece to be welded clearly enough, once you strike the arc? Looks like you missed it on some attempts.
  6. MBB Forum Supporter
    1,047
    northumberland
    That's even worse than my welds and I'm less than bad.
    stuvy likes this.
  7. mr migwire
    mr migwire It's more fun with metal.
    1,790
    fife
    as others have said max +2 settings and make sure the metal is cleaned back to shiny, make sure your return lead is clamped to clean metal to.
    ajlelectronics likes this.
  8. eddie49 Member
    Regarding your doubts about polarity: using solid steel wire with gas, the torch should be positive, and in your picture above, it is.
    The blue wire feeds from the + Dinse socket to the torch power input, and the earth cable is plugged into the - Dinse socket. All is O.K.
    As has been suggested above, before making actual joints, practice by just laying straight beads of weld on clean shiny 3mm sheet metal.
    If you are trying your first-ever welds with just the simple hand-held shield that is usually supplied with basic welders, you'll find it difficult. I'd recommend getting an automatic self-darkening helmet.
  9. paulo1974 Member
    152
    porto
    i can´t see the piece after i start the arc . Maybe i must regulate my auto darking helmet to a brighter shade. the speed of the wire is ok or should it be slower?
    slim_boy_fat likes this.
  10. Seadog
    Seadog Forum Supporter
    6,475
    NE London - UK
    A bright light helps too.
  11. Lazurus
    Lazurus Member
    873
    Norfolk uk
    Being a newbie myself, turning mask to shade 10 and a big bright light illuminating the work site made a huge difference, even with a cheap helmet. I also went for a cheater lens, again a revelation.
  12. MoreWellie Member
    1,190
    Bedfordshire, UK
    it looks like that metal is coated with something. If it is galvanised then the fumes from welding are particularly bad for you and if it is something else then that may be one reason you are having problems but I think this is more than one problem
    I suggest starting with clean steel and trying to lay a weld on that
    how much flow have you set on the gas? somewhere around 7 litres per minute would be about right
    how far was the nozzle from the metal? somewhere around 5 to 10mm would be a good starting point
    have you read the tutorials in the Mig section at the top of the page?
  13. daedalusminos Member
    896
    Norwich
    Everything that's been said before.....is that solid rod or tube? If solid I'd bias towards that .... But your main problem is not being able to see!
    gt6s likes this.
  14. slim_boy_fat
    Can I ask what strength you went for, and a link to source please?
  15. gaz1
    gaz1 Member
    10,752
    westyorkshire
    if thats 5mm or 10mm round bar your trying to weld with that mig welder not a chance every weld you do is going to be cold blobby
    back up and try to weld the thin stuff on its own with that mig
    id be welding that with arc not with a mig welder
  16. paulo1974 Member
    152
    porto
    i got a second weld on that piece.
    i follow some advices and i got a good weld.
    1- bought a sheet of steel to make my welding table so i could ground the piece without any problem.
    2- set the machine to full power
    3- got my mask from 13 to 11 so now i can see what i was doing
    4- the wire speed was moved from 7 to 8 speed of 10.
    5- cleaned the two pieces to weld
    6- also put the nose of the torch closer to the work piece
    7- rested my hand on the pieces so i can get the two pieces without any gaps
    on that first pictures my welds sounded like popcorns with this changed to the setup my weld sounded good.
    MBB likes this.
  17. gt6s Member
    790
    Newtownards Co Down Northern Ireland
    After looking at those "WELDS" I cannot see.:scared:
  18. postie jon Member
    864
    Aberdeenshire, Scotland
    after 2 days of gastroenteritis ,seeing this has perked me up. sorry:fighting:
  19. KennethSmith New Member
    2
    New York
    Looks messy:o
  20. Pigeon_Droppings2 Member
    2,808
    london
    Wonder if some of the problem is position?....are you resting the torch on your opposite hand or just firing from free space? When I started out I tended to strike the weld and then pull the torch away...took me a while to get a steady hand....used to wave it around like a light sabre when I started!
    As others have said...is the piece nice and clean before yo started...including under the earth too.
Advertisements
