Fiesta cutting out when braking hard.
  1. zardoz
    zardoz Old school Socialist
    2,219
    Chetser, UK
    I bought an 04 petrol fiesta 1300 7 month ago. From the get go it cut out when braking hard or even not so hard. It was such a good car in every other respect that i thought, what the hell Ill just keep it and fix it, in the meantime not stamping on the brakes.
    Well i looked it up and got all sorts of answers, fuel sensor, fuel filter, idle speed control valve, lambda sensors, etc. One of the weirdest but simplest 'fixes' was to disconnect the battery for 20 minutes. So i tried that first and hey presto it worked. ! well for all of 4 months now its back again. So i have turned to the most knowledgeable people i know. ie: this forum.
    Any one here able to help ?
    ps happy holidays
  2. zardoz
    2,219
    Chetser, UK
    Good question, will try in the morning.
  3. The_Yellow_Ardvark
    The_Yellow_Ardvark perkele
    13,183
    England
    @zardoz
    Check/replace the hose from the brake servo to the fuel system.
    Mother in law Fiesta had the same problem.
    Turns out when heavy breaking the servo allowed the inlet vacuum to leak out, weakling the mix to the point the engine would cut out.
  4. Robotstar5
    Robotstar5 Casanunda Staff Member
    18,144
    Birmingham
    I had a Mini where the engine would rock forward under engine braking and short the main battery cable against the hot exhaust.
  5. Vacuum leak on manifold somewhere
  6. Badger1bear
    Badger1bear If your not on fire, then your too far away
    2,193
    kent
    Keep it simple
    Check earth straps
    Thank me later
    doubleboost likes this.
  7. Justme
    Justme Member
    3,002
    Pwllheli Wales
  8. I have developed a habit when I want to acknowledge people following me (like a thank you for letting me pull out etc) to dab the brake pedal to flash the rear brake lights but on the VW T5 the engine cuts out momentarily. Perhaps the Fiesta has a similar setup and the throttle is adjusted too high? Just a stab in the dark.
  9. Chop 13 Member
    10
    Manchester
    My vectra was doing that turned out to be the crank sensor!!
    Exuptoy likes this.
  10. the snooper
    the snooper getting older by the day
    20,517
    Hull UK
    most people will think your just twitchy on the brakes :D I flash the hazards momentarily
    Rig Pig, normspanners and Exuptoy like this.
  11. Robotstar5
    18,144
    Birmingham
    If I saw that I would assume you were braking and start doing the same myself, I use a couple of flashes of the hazards instead.
    Migmac and slim_boy_fat like this.
  12. dobbslc
    dobbslc Member
    5,382
    Hertfordshire UK
    Yeah left right flick of the indicators for me.
  13. I don't jam on the brakes just tap two or three times in quick succession. Anyway, it's not about my habits, I'm just thinking the reason for the intermittent cutting out is the brake light circuit when on the accelerator may be causing it.
  14. Justme
    Justme Member
    3,002
    Pwllheli Wales
    Modern cars cut the gas if you are braking.
    Some even give error codes if you have a foot on the gas & brake at the same time.
    Are you dipping the clutch at the same time?
  15. Robotstar5
    18,144
    Birmingham
    I found that after going through a ford in the Navara, tried applying the brakes to dry them and the engine lost power.
  16. zardoz
    2,219
    Chetser, UK
    Just tried it twice and didn't happen when i had the clutch in too. So unless its a massive coincidence it might be indicative of ......?
  17. waddycall
    waddycall Member
    1,143
    United Kingdom
    Would this mean it's more likely to be something shorting/disconnecting as the engine moves around as with the clutch in the engine won't move on the mounts so much?
  18. Aaron_ Member
    186
    Middlesex
    Try this unplug the plug on the speedo bit on the gearbox if that fixes it you will need to remove the throttle position sensor elongate the holes and then refit can't remember what wires just you need to set it to 0.7v that should fix it
    zardoz and Exuptoy like this.
  19. This is why I suggested it in case the same thing applies with the Ford as my T5. Forgetting my bad habits, the point is with a partial throttle and brake applied the engine hesitates and cuts momentarily.
    Aaron_ likes this.
  20. Can'tWeld can sort of weld
    I'm wondering about this. Never encountered it for myself, but I recall being told that old Fords had a crash sensor which was basically a tube with a ball bearing inside, under extreme deceleration the ball bearing would shoot forward and cut power to the fuel pump.
    Perhaps find out where it is and bypass it?
    Do modern cars even have that any more?
Advertisements
