Tinbasherdan
Bodger in chief
- Bolton, England
first up, anyone with experience of en24T? specifically machining prior to heat treating. im going to be remaking an input shaft/gear for my landy as i dont rate the off the shelf option, its a toss up between 19 and 24 at the moment but in any case....
how much does 24 tend to move when being heat treated? is it wise to leave a few thou to be ground down later or does it not really matter? it has two bearing lands which need to be reasonably spot on to prevent the bearings spinning on the shaft.
and secondly, is anyone on here capable of doing helical gear cutting? i have no idea how to measure pitch of a helical gear so best i could do is send the original gear
cheers
dan
cheers
dan
