Hi im a newbe and this is my first post, and im a novice to welding; yesterday i had a go on my uncles Clarke weld AT100 arc welder bought from machine mart about 11 months ago. So, i set it up as in the instructions and it was doing as it should. So after 20 minites i decide to pack up, switch off the machine ect; so i take the standard 3 prong 240v plug out the wall (my hands were touching the plug prongs (the plug was removed from the socket) and im getting a tangy shock sensation (nothing heavy but noticeable), touched it again and the same sensation, then once again and it was ok.
So what i want to ask is what may have caused this as im paranoid now about using it again. Could this be caused by a bad earth clip on the welding leads ?, build up off static ? Is this normal ? do i have to earth the machine?
Hope someone out there can put my mind at rest, another question is this; can shocks off a small welder like mine be fatal? as it is DC which is more dangerous right?
And while im here one more question, whats the best rod to use for a stainless steel (motorcycle) motad exhaust ????
Thanks for any response in advance its much appreciated ?
