I have been thinking of doing this for some time. So 32" TV how would you design it to lower from the ceiling?
Depends how much space you have above, the motor mount I have for my TV states it can be used upside down to drop down from the ceiling, alternatively you can get some that fold up - but they need a lot of space to swing and look a mess when up or down. It is normally better to have it motorise up out of something if you can.
Do you mean so that it's hidden completely when retracted? i.e above the ceiling. Few years back for a project in London I made a TV mechanism that hid a 55" screen, it had a huge artwork piece on a metal frame that used slides to move the artwork sideways to reveal the TV. No track or mechanisms on show at all. It was quite a feat! Was all controlled by the main system so that when you selected the TV, the slide started and everything turned on. Think I have a video of it somewhere. I have accounts with people that make off the shelf mechanisms to do all sorts but they are big bucks. Andy.
I know enough to know that cheap winches are noisy unreliable and just about to fail when you most need them
Then you just need to build a box above, cut a hole in the ceiling and use something like https://www.ebay.co.uk/itm/28-Autom...h=item4427c81051:g:Gz8AAOSwIFtaCmnh:rk:3:pf:0 the unit screws into the containment box, you put an infill ceiling piece to cover the hole on the bottom and mount the tv - most tv lift units will work upside down but it is best to specifically ask the seller as well. Simpler option is something like this https://www.ebay.co.uk/itm/Allcam-E...m=372074637776&_trksid=p2047675.c100008.m2219 but they look a mess and are always on display
The other thing to bear in mind is that the screen needs to be at eye level in use. You will very soon get fed up of sitting craning your neck, besides the fact that may damage your neck muscles. This is why the "Over fireplace" fashion died out so quickly.
Thanks it looks expensive but by the time you look at buying all the odds and ends to make one its good value, I did buy one a few years ago then found it could only lift and not lower I will give it more thought.
i did the opposite and built a cabinet with a lift in it. I looked at all the options, and in the end went for a proper linak actuator..... cheap it wasnt, but it gets used every day, and hasnt missed a beat in the 5 years its been in use..... could i have built somethign simialr that worked, yes, certainly, but it would almost certainly have been comprimised in some way or another. Im pretty much the patreon saint of tight fistedness, but decided with this one to just pay the money and get the elegant solution. May not be the same in your case, but i was seriously spacially challanged, and it was the only way i could see to meet the required parameters....
I just can't fit an end of bed one it. Had a good look at all the Ebay lifts and none are really suited to dropping the TV down. Quite looking forward to doing it just have to try and get all the bits cheaply, work threw loads of draw runners away last years I only got one pair as it was all I needed at the time!
Server runners might do although they tend to only extend the depth of the server - 700mm - 900mm ish
just use a bed motor https://www.ebay.co.uk/itm/Linak-be...=item3afbe58790:g:OvMAAOSwkLhaRSBT:rk:18:pf:0
Father-in-Law just bought a pair of 1000mm ones, with a magnetic closer, from eBay for a pull out drawer in his Hilux, I’ll see if I can find out more.
