So guys I'm running an ABAC PRO A39B 200 FM3. During long sandblasting sessions I'm getting clogging due to moisture. The compressor is running almost constantly during sandblasting as I run it at around 110psi. So it gets pretty hot. I run around 5m of line from the air compressor to a 3 stage filter (https://www.solenoid-valve.world/sh...jdHrGemvxmLTLmfqJCqVVX8iy3NW3JOMaAjRSEALw_wcB)
From here I run 2m of line into a air hose reel which I then extend for use of my air tools, spraying and sandblasting etc.
I drain my compressor regularly ( 45 min, for 30 seconds) using an auto drain valve.
Should I upgrade to a higher CFM compressor or would including a drop out filter help? It's putting out around 14cfm.
If so, does anyone have recommendations for a drop out filter suitable to my CFM output?
