Driveway lights water problem
  1. 123hotchef Member
    7,412
    Kent
    Hi people
    My mate has a problem with his driveway lights keep filling up with water and tripping the RCD
    Anyway we have tried the Raytech gel it worked for a while but he thinks they are filling up from the bottom and the water eventually pushes the raytech gel up and it seeps into the housing.
    I said maybe we can try something else? Does any one have any recommendations?
    He want me to do the job for him so I would like it done right
    Lee
  2. eLuSiVeMiTe
    eLuSiVeMiTe Forum Supporter
    7,701
    Bedfordshire England
    Disconnect the supply and cut a new block in the hole. :) problem solved.
    On a more serious note. Pull the lights out. Drill a big hole down into the sub base and fill with pea shingle.
    Give the water somewhere to go. No idea if it will work but worth considering. It shouldn't be holding water anyway if it was excavated to depth and installed correctly.
    Got a pic of the drive.
  3. 123hotchef Member
    7,412
    Kent
    i dont have a pic of the drive but it was a pukka job truck loads of type one then re inforcing mesh then concrete then the blocks
    I did think about pulling the lights out and drilling down but the bases are bonded in! and the cable glands are in the bottom decent glands too but you know water
  4. eLuSiVeMiTe
    7,701
    And what provision was put in to drain the water passing through the blocks to the concrete base.
    Can't understand the trend of laying blocks on concrete.
    @spencer 427 ever seen it done.
    spencer 427 likes this.
  5. spencer 427
    spencer 427 Member
    5,780
    uk colchester
    uk colchester
    Have done it over drylene. They use to do that on site years ago.
  6. spencer 427
    spencer 427 Member
    5,780
    uk colchester
    uk colchester
    Also laying blocks over concrete is not a good idea as they will eventually rock loose
  7. eLuSiVeMiTe
    7,701
    Aye. Still allows some movement and acts like sand screed when it does break down. Should still let water pass too I suppose.
    We used to use granite sand. Wet it up while compacting for similar results.
    Polish lads I worked with on jersey laid on granite chippings and seemed to work well.
    @123hotchef do you know what if any drainage they put in to remove surface water from under the blocks.
  8. 123hotchef Member
    7,412
    Kent
    all the blocks are granite they were all laid into concrete it is not block paving all the joints are resin grouted
  9. 123hotchef Member
    7,412
    Kent
    the blocks are sealed after the water runs off to the drain
  10. Matrixx
    Matrixx Member
    398
    North Duffield
    RTV or ip68 lights?
  11. 123hotchef Member
    7,412
    Kent
    RTV silicon? The lights will be a ball ache to remove as they are bonded into the core drilled pavers and the cables look pretty tight too
  12. eLuSiVeMiTe
    7,701
    How long has the drive been down out of curiosity
  13. 123hotchef Member
    7,412
    Kent
    over a year now maybe 2
  14. spencer 427
    spencer 427 Member
    5,780
    uk colchester
    uk colchester
    With lights installed in a drive there is normally a French drain that takes the water away to a soak away . If no drainage was installed it's going to be a problem
    mike os and 123hotchef like this.
  15. JohnRUFC Member
    226
    Rotherham
    What IP rating are the lights?
    Ideally, you need IP69K.
    123hotchef likes this.
  16. 123hotchef Member
    7,412
    Kent
    I have no idea what ratting the lights are TBH I didnt purchase or install them I am just trying to over come the problem for him
  17. 123hotchef Member
    7,412
    Kent
    this was the type of driveway
    [​IMG]
  18. knighty Member
    1,625
    Sunderland
    can you open them up and fill them with something else?
    some kind of acrylic/resin?
    I made myself a back light of my electric bike years ago, solcered a load of LEDs onto a circuit board then put it in an old chinese food tub and poured clear resin on top... let is set and job done
    only thing is.... I have no idea what that stuff was called (forgot some things when I fell on my head).... mixed main stuff with a hardener, stirred then poured it on... it set rock hard (and transparent)
  19. spencer 427
    spencer 427 Member
    5,780
    uk colchester
    uk colchester
    Granite sets . They are a pain to lay
    eLuSiVeMiTe and 123hotchef like this.
  20. 123hotchef Member
    7,412
    Kent
    it was a big drive took them a couple of months
    grim_d likes this.
Advertisements
