steveo3002
need some shims /washers 14mm outer x10mm hole x0.2mm thick
does such a thing exist , not seeing any
I don’t know whether you can buy these but rebuilding a gearbox recently I discovered that it’s easy enough to make shims if you have a lathe. Sandwich the shim stock between a couple of thicker pieces and skim over to required diameter.
just a couple or so ..will try the drilling /scicsors idea firstmight know a man who could laser cut... how many you need?
Now THAT I'm going to remember . . . I had to enlarge some shims to rebuild a ZF transfer box and struggled - I never thought of sacrificial holding fixtures!
