My newest project is going to be welding a dining room table frame and putting a rustic wood top on it. The chairs will be a L shaped counter height bench. Im having a hard time designing the bench. Obviously for comfort the Back should be angled but do I also do the same angle on the rear legs? Stability will not be an issue because it will be against a wall. If so, what is the preferred angle of both? and if I angle them is it better to cut the angle and weld it back together or should I attempt to put a bend in the metal without cutting it? I'm think of using 1 1/2" square tube. I appreciate all responses.
Thanks,
Marc
Thanks,
Marc
