de-rusting box section internals
  1. bigegg
    bigegg I drink and I know things. Its what I do.
    6,932
    Leeds, West Yorkshire
    i'm in the process of converting a caravan chassis into a box-van trailer cum workshop shed.
    its an old chassis, not galvanised and with a fair bit of surface rust. nothing terminal, however.
    its all 3mm c- section, except for the main front-back beams which have been enclosed by a piece of 3mm plate, for a length of about 6ft.
    as far as i can see, the inside of this "box" is as rusty as the outside.
    is there a clever way of derusting it, prior to coating with rustproofer?
    i'm going to derust the accessible bits with a wire brush, then paint the lot - I' m thinking a high zinc primer, and then lathering with underseal.- its likely to spend a lot of time being dragged across grass fields for car boot sales.
  2. gaz1
    gaz1 Forum Supporter
    9,855
    westyorkshire
    grinder wire wheel but be careful with it
  3. eLuSiVeMiTe
    eLuSiVeMiTe Member
    10,856
    Bedfordshire England
    wyn likes this.
  4. eLuSiVeMiTe
    eLuSiVeMiTe Member
    10,856
    Bit of twin and earth in a conduit. Spin it with a drill and split the ends to act as a flail
    rtcosic, jimbo84, bigegg and 2 others like this.
  5. The_Yellow_Ardvark
    The_Yellow_Ardvark Member
    12,471
    England
    FP200 works as well, I have few miles here.
    Done similar on 4 Die Holders handles to day.
    eLuSiVeMiTe likes this.
  6. bigegg
    6,932
    ta very much.
  7. 8ob
    8ob Forum Supporter
    5,176
    moscow on thames
    Rust cant continue without moisture and air, just blast wax up there when you have finished welding bits to it . We can all get a bit hung up on the "rust" word when in reality it can be a better coating than paint.
    Bob
    cianh91, johnser, minimutly and 2 others like this.
  8. bigegg
    6,932
    couldnt get a grinder wheel in without an 4ft extension arbour
  9. eLuSiVeMiTe
    eLuSiVeMiTe Member
    10,856
    Use it on trials bike exhaust pipes to clean the crud out.
    Sticking them on a hot plate in the garden works well too but there never shiny again.
  10. CompoSimmonite Member
    4,365
    Werrington, Stoke-on-Trent
    Cut the web out, derust to your satisfaction then reweld in the web ?
    bigegg likes this.
  11. ronan
    ronan Forum Supporter
    9,436
    dublin
    Take it to the local sandblasters ? Blanket bomb it with 2k epoxy after.
  12. bigegg
    6,932
    thats going to be favourite i think - irs onlt half a dozen 1in welds
  13. rtcosic
    rtcosic Member
    You didn't tell us that crucial piece of information and I was too lazy to zoom in on your photographs.
    I do like the flail in a tube though and have added that to my portfolio of rust treatments to experiment with - along with electrolysis, citric acid, oxalic acid, hydrochloric acid with hexamine, phosphoric acid, wire brushes, sand/grit/bead blasting, needle gun, scraper................
    Parm and bigegg like this.
  14. bigegg
    6,932
    i didnt spot it myself at the time of the OP : they sort of blend in with the rust.
    :rolleyes:
  15. rtcosic
    rtcosic Member
    I believe you. I'm gullible like that.
    bigegg likes this.
  16. bigegg
    6,932
    you do know that word is disparaged now?
    its even been removed from online dictionaries.
    :whistle:
  17. eLuSiVeMiTe
    eLuSiVeMiTe Member
    10,856
    Huh. Who'd have thought it...
    bigegg likes this.
  18. Pigeon_Droppings2 Member
    2,424
    london
    Make a giant citric acid bath...some DPM and bits of wood to form a shallow pool...might have to figure a way to agitate things.
    bigegg likes this.
  19. bigegg
    6,932
    i had actually considered that. :laughing:
  20. The_Yellow_Ardvark
    12,471
    England
    :scared::scared::scared::scared::scared::scared::scared::scared::scared::scared::scared:DC Arc welder for sale:whistle:
    Parm likes this.
Advertisements
