cut 50 stopped working
  1. hifly Member
    Hi,
    Not used it for some time, working when put away.
    when turned on all seems ok,
    pull trigger, air comes out, arc strikes then red light comes on (lock light)
    I have lifted the lid and the spark gap is arcing nicely when trigger is 1st pulled, but not after the initial arc to work has been struck.
    can't see any burn or damaged components.
    any thoughts? have a few jobs to do now i have the time and then this, typical.
    any help appreciated.
    Cheers
    Vince
  2. Memmeddu
    Memmeddu Member
    1,966
    Italia Sardegna
    Maybe some pictures would be helpful for someone expert that could solve the issue
  3. the snooper
    the snooper getting older by the day
    20,291
    Hull UK
    Have you taken the torch apart to check the parts are still serviceable, is the air pressure ok
  4. skotl
    skotl Forum Supporter
    6,757
    Edinburgh, UK
    Sadly, you probably need to dismantle it and check each board. When mine went phutt (similar symptoms) there was nothing obvious till I started dismantling it.
    Memmeddu likes this.
  5. hifly Member
    put all new consumables in the torch.
    tried air pressure from 40 to 80 psi.
    some progress, after leaving it turned on (no cover) in the sun for an hour it has done a cut of about 600mm before it cut out, so my current thoughts are that it is damp and some drying out may fix the problem, i will give it a try in another hour and see if there is any improvement.
  6. the snooper
    20,291
    Hull UK
    May be a connection go e bad with damp, if all else fails unplug any plugs you can see the plug back in
  7. hifly Member
    Ok, seems sorted, managed to get the most important job done (cut barrel in half for the misses) looks like it may just have been damp and leaving it on with the cover off in the sunshine seems to have fixed it.
  8. gaz1
    gaz1 Forum Supporter
    9,528
    westyorkshire
    you shouldnt be below 60
    from skotl as there a good guide even for me to use them and have no problems
    I set the air at about 65psi and never touch it after that.
    12 mm would be at 50A
    8mm at 30A
    6mm at 20A
    3mm at 15A
    slim_boy_fat and Memmeddu like this.
  9. dannyp Member
    you change the current settings ? mine has been set flat out from day 1
  10. gaz1
    9,528
    westyorkshire
    no ive set mine as close to the material and adjust for variable differences on the dial
Advertisements
