Brad93
- Essex, United Kingdom
Right im pretty much set on buying a multifix from Create.
But, I'm very confused as to what size i need.
I know i need an A or an E. Ideally, I'd like the larger one, because if i ever upgrade the lathe, the toolpost is staying with me.
So, the centre height on my Harrison, from the surface of the compound slide to the centre of a turned workpiece, is 37mm roughly. I will need to check this again.
This is where I'm confused.
Create tool show one figure, rotagrip show another, and this site shows another. http://www.schnellwechselhalter.de/
Which is correct?
Also I've got 20mm tools, I'm guessing I want 25mm holders?
20mm holders could be a tight fit on the tool?
Confused. I'm 90% sure i need a E size with 25mm toolholders.
Which is correct?
