W.olly
- Radcliffe, Manchester
This may be a daft idea, maybe not, but if you dont ask hey. Will saave on buying a cut offtool aswell for the few jobs i do. Or stick with my angle grinder.
Got one of these that run free at 5500rpm with a 254x30 blade and 2000w.
I have een looking for steel cutting discs to see if i can find one that will fit with the 254mm or little less. But main problem is the bore so mite have to use a shim if i can find a steel cutting disc for it..
Should i forget it, i just see if the blade will fit and take the 5500rpm it should also cut steel box section.
i await
i await
