Colchester Triumph
  1. David56 New Member
    4
    London england
    I want to buy a colechester triumph 2000. With a 5.5 kw motor.
    Does anybody know if there is an inverter that can run off a 32amp 240v that will run it.
  2. MBB Forum Supporter
    1,047
    northumberland
    I changed the 3/5 hp two speed motor on a roundhead Triumph to a three hp, worked fine with a inverter.
  3. Seadog
    Seadog Forum Supporter
    6,475
    NE London - UK
    That's not 5.5kW though :whistle:
    In theory you'd only be drawing, I guess, 25A. It sounds possible but I'll wait until someone who's done it comes along to shoot me down :laughing:
  4. Pete.
    Pete. Member
    9,431
    Kent, UK
    I don't think you'll find a domestic-market 5.5kw VFD, I remember reading somewhere that only up to 3hp or 3kw were 'approved' for UK domestic but I can't find the source of the info any more so it might be all bullwash. You can find Chinese units that powerful but you take pot luck on the quality.
    You could always build a rotary converter.
  5. MBB Forum Supporter
    1,047
    northumberland
    Vary rarely you will be using the full 7 hp on the lathe 3 hp is quite adequate for most operations and you will still be able to take large cuts on the lower gear range.
    fizzy and eLuSiVeMiTe like this.
Advertisements
