Hi guys
Hoping one of you knowledgeable chaps maybe able to help me. I am still learning to use my lathe and think I may have damaged it. I was doing a cut with the feed and set the stops on the carriage to stop at same place. The idea being to stop the feed just before the stop then hand wind to the stop. Unfortunately I couldn’t disengage the feed before it hit the stop so I hit the e button. I could disengage the feed lever as it was tight against the stop. I managed to wind the stop in and disengage the feed.
Since this happened the feed does not work. I have taken the end cover of the drive end and the cogs are all driving(it runs when the cover is removed). I have read that there is a shear pin but I think that hasn’t sheared and it’s something in the bottom gear box. Pics below if any help. The pic of the drive end was taken when the lathe was running and all cogs were turning but the feed screw wasn’t. I hope I haven’t damaged it beyond repair.
cheers in advance
cheers in advance
