Clarke 100E MIG Gas Control
  1. masonmjs New Member
    2
    Edinburgh, UK
    Hi,
    I am a complete beginner to welding of any kind and have bought the above machine for essentially 1 job I have on the car (although no doubt it will come in handy for other jobs as they come up).
    I have replaced the liner with a wire one, and also the swans neck liner and am looking at the gas regulator (bottle end) currently as it looks a bit dodgy (it only seems to work over the last 25% of travel).
    But the main problem is that I can hear gas escaping out of the welding nozzle (apologies if I don't have the terminology correct) without pressing the trigger. I thought the trigger also controlled the flow of gas so it would be OK to set the gas to the preferred setting before I start welding and leave it on for the duration but that does not seem to be the case.
    Do I have a defective swans neck or is it meant to do that ?? I have been inside the trigger several times changing stuff so I know there is a block in there for connecting the liner and the gas tube, is there a valve in there controlled by the trigger ?
    I spent a few hours today practicing but it looked terrible, I managed to tune the machine up to give a nice smooth wire feed but it now seems that my gas flow was entirely inadequate, when I turned the gas up full I made my first decent looking weld.
    Thanks in advance
    Cheers
    Mike
  2. Cobbler
    Cobbler Codger bodger
    4,924
    Gloucestershire UK
    Hi there, the block in the torch that the swan neck screws into is also the gas valve. The seals in this get stiff & sticky sometimes, give it a squirt with some WD40 of similar & work the valve a bit & you will probably find it’s ok then.
  3. masonmjs New Member
    2
    Edinburgh, UK
    Ah OK thanks, so the brass knob activates the gas valve and the trigger shorts out the metal spring to activate the welder ?
    Makes sense now you mention it ...
    Thanks for that
    Mike
Advertisements
