I am trying to retro fit a gearbox to a bellhousing,
yes a adaptor plate would be the easy option, only the original bellousing is very very weak.
its very thin cast alloy,
i was thinking of a new thicker bellhousing with no need for the adaptor plate if a can get the diamentions right
I'm not sure about ally but from what i've seen on various documentaries about cast iron the pattern needs to be a ?% bigger to allow for shrinkage of the metal as it cools[/quote patternmakers use a shrinkage or so called patternmakers rule .the graduations are calibrated for varous metals for shrinkage . its a bit tough sh ,./,././,t if u buy one and dont notice till u have cocked up a load of your jobsa friend of mine cut an 1/8 th of a steel rule at college by accident on the guilotine . there was a lot of head scratching for a few weeks till it was noticed
http://artisanfoundry.co.uk/store/p...d=206&osCsid=932b7bbb45af1524a27fd64a7709dd8e
Not sure if this is going to help any,
But the bellhousing is from an early Triumph GT6 mk1
The gearbox I want to fit is from a Fiat twin cam as in a Mirafiorie
I might just make a mock up adaptor plate out of MDF first, JUST to see if its going to work.
I hate modified gearbox tunnels on Spitfires/GT6,s
so if it fits and is do-able, I might move on to the second stage of a stronger bellhousing with no need for the seperate adaptor plate.
