Memmeddu
- Italia Sardegna
I'm studyng about carbon arc gouging.
I have few questions about...
First the power supply
how much tension?
how much amperage? (minimum)
I know that the minimum is 200A can works also whit less current?
AC-DC or only DC?
Second the holder /torch
I see that there are different amps but i see also that there are different rods (flat,round)
It's possibible use the same older for the different rods?
The design of this holder /torch is similar for many productors, but is possible turn the air jet nozzle to different positions for best work confort?
It's better a holder/torch that use a single hose/lead (air and current in a single hose as plasma torches) or one that use a air hose and a lead?
How can i properly call this strument? Holder?torch?clamp?
Thirth rods
Wich differences beetwin flat or round rods? What kind of works?
I see on ebay 4mm carbon rods, rated for max 250amps...
How much current can i use for (minimum)?
How use this rods?
They have a not covered zone, is it the first part that must touch the work piece?
Modus operandi
How strike an arc?
Drag?
Push?
Air pressure?
Wich works it's better do whit carbon arc and wich whit a plasma cutter?
There are some tricks?
Thank you
I hope to not been boring, but i would learn something about.
I'm Sorry for grammar mistake and or for bad world location.
There are some guide for carbon arc or i'm the first that ask to much about
how much tension?
AC-DC or only DC?
Thirth rods
How use this rods?
Modus operandi
How strike an arc?
Drag?
Push?
Air pressure?
Thank you
