Rod end likely to be cast steel than cast iron - have you tested to see what it is?I have to going a mild steel eye to a cast iron ram end. Can I use Nicole rods as root and lay a pad on the iron face then use mig to preform the rest of the weld .will the mild steel wire hold to a ferro nickle base
Has anyone tried this?
If cast steel, preheat and weld as normal with slow cooling.
If nodular/grey cast iron then nickel all the way out
