Bucket sides
  1. F.J.
    F.J. Member
    1,773
    Manchester
    Today I have been cutting out and preparing the sides of a 70 ton bucket as the existing sides had work through.
    This heat was crazy hot but at least I will keep the weight off! I had sweat running off my chin like a tap and my overalls were wet through!
    I’d of had the job finished today but my van broke down on my way back the welding supplies which put me back 4 hours!!
    Tomorrow I just need to make sure the 20mm thick panels fit as they should then weld them in..... more pictures to follow tomorrow
    Thanks
    ronan, steve t, johnik and 13 others like this.
  2. Bear
    Bear Member
    339
    Manchester, UK
    So are you back working for yourself again @F.J. ?
    Kent likes this.
  3. rory1
    rory1 Member
    1,093
    Macclesfield
    Been painfully hot today hasn’t it. I’ve been bore welding loading shovel
    Buckets and was sweatier than a glass blowers bum
    steve t and F.J. like this.
  4. Screwdriver
    Screwdriver Member
    5,269
    UK London
    Amazing. I enjoy watching people fix big iron like this. Any other Andrew Camarata fans on here?
    maz0, brianblock, wyn and 2 others like this.
  5. F.J.
    F.J. Member
    1,773
    Manchester
    Yes pal, and I’ve missed it greatly
    steve t and Bear like this.
  6. F.J.
    F.J. Member
    1,773
    Manchester
    Got the same again tomorrow only with welding involved! The bucket is upside down so I’ll need to climb under to get inside!
    steve t likes this.
  7. Yamhon Member
    926
    Earth
    May I ask what vehicle you use for self employed fab/welding? It's something I'd like to have a go at, can't decide on what vehicle would be most practical to the role?
  8. colnerov
    colnerov Member
    3,237
    Nr Gatwick UK
    Hi, Yes to Andrew Camarata and Chris Guins (aka letsdig18) Chris is smoother and quicker with the newer equipment which only requires general maintainence, but Andrew has to spend time repairing his stuff because it's more err... tired.
    Colin
    lundtang and Yamhon like this.
  9. Yamhon Member
    926
    Earth
    I watch them both; I like Andrew's channel because of the variety of stuff he gets up to, and of course Levi :-)
  10. TechnicAl
    TechnicAl Member
    7,084
    Rotherham
    Hardox?
  11. F.J.
    F.J. Member
    1,773
    Manchester
    I have a LWB transit van. I need to fit a tow bar to it as they are not that big once you have fitted the generator and racking etc..... but I used to have a LWB sprinter and sometimes it felt like I was lugging around in a cruise liner.
    It wasn’t a certain preference, I was also looking at MWB sprinters, Crafters and Ivecos but the Transit came up closest to home, one owner and within budget, I just got bit yesterday with the belt slipping off but that’ll be sorted tomorrow
    Thanks
    Yamhon likes this.
  12. F.J.
    F.J. Member
    1,773
    Manchester
    Not Hardox no! When I told the customer the price of a sheet he fell off his chair, I’m using normal carbon but welding hardox wear bars around the back edge where it had worn through
  13. Yamhon Member
    926
    Earth
    Thank you for sharing that, I'll have a look into those options.
    F.J. likes this.
  14. TechnicAl
    TechnicAl Member
    7,084
    Rotherham
    OK....is it that expensive?...there are other brands that have similar properties....cant remember the names at the moment
  15. Parm
    Parm I have fun doing stuff
    10,062
    Towcester
    steviec_lj likes this.
  16. F.J.
    F.J. Member
    1,773
    Manchester
    A sheet of 2m x 1m 20mm thick Hardox is £730! I got a sheet of mild the same size for £196 delivered!!!
  17. TechnicAl
    TechnicAl Member
    7,084
    Rotherham
    wow
  18. F.J.
    F.J. Member
    1,773
    Manchester
    That’s what I said but a bit more colourful! Both pieces were cut from a 1m x 1m section of the plate so I’ll be making a nice but small heavy duty welding table soon
  19. Yamhon Member
    926
    Earth
  20. steve t Member
    539
    Ireland
    Good to see you posting again fj
Advertisements
