brazing copper piping
  1. cornishnutter Member
    41
    suffolk england
    hello guys and guys was wondering if anyone can give me tips on brazing cos i ahve have never done it , and im starting a new job working with copper piping
  2. brightspark
    brightspark Member
    24,967
    yarm
    brazing or soldering??and what size pipes . u can braze with a propane torch or oxy acet or oxy propane depending on the heat required
  3. Rrunnach
    Rrunnach www.interventiontechnolog y.com
    1,004
    edinburgh
    Good flame setting, clean material, rod well fluxed, or pre-fluxed rod. Don't cook the pipe, rod will flow easily around joint via capillary action.
    What you doing, heat exchangers/air-con?
  4. cornishnutter Member
    41
    suffolk england
    i am doing refrigeration rfor a company so do i just heat the metal up and it melts together or do i have to use rods as well like gas welding/
  5. Rrunnach
    1,004
    edinburgh
    Refrigeration normally use a copper type rod for their work, I can't remember the spec, have used them, dawdle to use..
  6. voipio Member
    589
    Cambridge, UK
    Think of brazing as high temperature soldering of pipes. The fluxes are different and based on borax. There are plenty of videos on youtube to show you how. The copper doesn't melt in the process, else that would be welding.
  7. rtbcomp
    rtbcomp Moderator Staff Member
    18,173
    Sheffield UK
    Brazing is like soldering but with a brass alloy rod. The metal pipes don't melt, but the rod does and flows into the joint.
    If you melted the pipes together that would be welding.
  8. Rrunnach
    1,004
    edinburgh
    Good for you on getting a start. How did you manage this if you have never brazed before, company training you up?
    Shedendman likes this.
  9. eil Member
    1,748
    N Wales
    You need a copper to copper / copper phosphorus rod, the higher the silver content the easier it flows, have a look on you tube.
  10. davidjohnperry a different breed
    1,915
    yate/bristol
    hya lad i worked for a air con firm for a while to braze the pipes they usually used a oxygen propane mix and Rothenberger Rolot S2 Copper is what we used as our brazing rods. u can use a plumbers blow lamp for quarter pipe work but it is easier to just use the oxey propane mix. my advice to you is buy two cutters for holding armaflex lagging back when brazing and have a wet rag. and if you have sculls look after them as they are quite difficult to come accross. hope this helps.
    also whilst i think about it dont know the hole truth about it as i was allowed to do it but I was told by an engineer that you cant work on any refrigeration pipe work unless you are f gas trained
  11. eil Member
    1,748
    N Wales
    David, what are sculls
  12. Tiggy_dorset
    Tiggy_dorset It looks just like a bought one!
    1,938
    Weymouth, Dorset, UK
    Copper to Copper - I use a self fluxing silphos rod
    Anything else, which includes : Brass, Mild Steel, Stainless - I use silver solder(Sil40) with powdered flux. Some people mix the flux into a paste with water, but I simply prefer heating the rod and dipping into the powder. I guess that would be a matter of personal preference.
    I use Oxy/Acet
  13. davidjohnperry a different breed
    1,915
    yate/bristol
    Hey eli mate sculls are pipe benders but are a lot more easier to use on the coil copper for bends then conventional plumber benders or external springs I think sculls if spelt right is the name of them. Hope that helps and before I forget this helped me all copper pipe work for refrigeration is imperial but most lagging is marker metric it was a night mare for me for a while till I worked it out . Good luck with your new job mate
  14. cornishnutter Member
    41
    suffolk england
    they saw I have welding and fabrication experience and they need someone in quick in their copper department
    Rrunnach likes this.
  15. cornishnutter Member
    41
    suffolk england
    cheers for all the help and advice guys
  16. Rrunnach
    1,004
    edinburgh
    Once you have nailed a few joints, you will see how easy it is.
  17. bonepyro
    bonepyro Forum Supporter
    120
    East Sussex
    Is this factory based work? Is there a clean up process after the brazing otherwise you will also need to know that all fridge pipework should be nitrogen purged when brazing to prevent oxide scale build up inside the pipework.
    As others have said above, copper - copper there is no extra flux, just the self fluxing rods. (I was 12 years an aircon / fridge engineer)
  18. cornishnutter Member
    41
    suffolk england
    yeah I t think there is
  19. Tiggy_dorset
    1,938
    Please let us know how you get on 'Cornishnutter'
  20. eil Member
    1,748
    N Wales
    Cornishnutter, my old man used to say to me "The trouble with you is you learnt to weld before you learnt to solder" meaning don't go too hot ;)
Advertisements
