Pipe Dreamer
- Herts, UK
While practicing outside corners, lap joints and butt joints on 2mm steel, I'm having problems blowing away corners, both at the start and end of the joints.
I'm using a pedal and backing off towards the end but that doesn't seem to be helping.
I've also tried moving back, away from the end of the joint to finish, but the end is already messed up, or the weld is stopping short.
I assume the main problem is too much heat, but any suggestions would be welcome.
