Bead Roller Cast or plate steel?
  1. Snowy90
    Snowy90 Member
    114
    Poor Part of Surrey
  2. Agroshield Member
    345
    The cast iron in the descriptions is misleading at best. About the only parts of the two machines that might be cast iron are the gears.
    Just for giggles, ask the eBay seller to tell you what parts are made of what material.
    stuvy and indy4x like this.
  3. frank horton
    frank horton V twins are great but 4"s rule.........
    1,575
    Soon 2 B Crete
    think, 4 that kinda money I'd b making my own.....
  4. Snowy90
    Snowy90 Member
    114
    Poor Part of Surrey
    I did think that but I do not have any form of lathe to turn items and the cost of the dies are incredibly expensive. £30-50 a set.
    So a complete set up is expensive but ready to go?
  5. Snowy90
    Snowy90 Member
    114
    Poor Part of Surrey
    So you think it’s probably plate with cast gears? I will ask
    stuvy likes this.
  6. Dcal Member
    1,611
    Antrim Northern Ireland
    I've the Metz version.
    As @Argoshield says its made out of plate and I don't think even the gears are cast (would be better if they aren't)
    I can't see much difference between them but I've only experience of the Metz one.
    With a few mods it can be made into a good tool with a lot of mods it can be made into a brilliant one.
    There is a thread on my mods on here somewhere.
    stuvy likes this.
  7. 500e
    500e Always buy fire insurance a flood is hard to start
    4,164
    SWest UK
    Metz says
    The machine is constructed of
    Flame cut rolled steel plate! Ensuring minimum deflection of the workpiece during forming operations
    Cormak say
    Made of cast iron and steel, it reduces the deformation of the shaped material to minimum
    (The gears look as if they might be cast)
  8. Snowy90
    Snowy90 Member
    114
    Poor Part of Surrey
    Or maybe they just mean the handle! I have asked but suspect you guys are right.
    If steel plate that makes it easy to brace as welding to cast is tricky
  9. mike 109444
    mike 109444 Member
    4,196
    uk Bristol
    Even the Metz ad includes the term "cast iron"
    Think some of the price for the Metz one is the stand as I am sure they use to advertise them without and separate price for stand.
    You should find lots of post where owners have beefed them up with some box along the length
  10. mike 109444
    mike 109444 Member
    4,196
    uk Bristol
  11. Snowy90
    Snowy90 Member
    114
    Poor Part of Surrey
    They look good too, maybe it’s get the best deal and assume I will need to beef it up.
  12. keithski122 Member
    947
    uk
    I f you get one and don't motorise it then replace the handle with a car steering wheel, easier to control the wheel than rotating a handle.
    anjum, Wallace, Snowy90 and 1 other person like this.
  13. willie.macleod
    willie.macleod Member
    57
    Western Isles, Scotland
    Amazon have cheaper still - looks like the same tool, just rebranded - link here.
  14. Snowy90
    Snowy90 Member
    114
    Poor Part of Surrey
    Thanks looks like the same one is on the bay at £129.00
    Looks good value
  15. Wallace
    Wallace Member
    6,659
    Staines, Middlesex, England.
    I bought a Metz specifically to modify, it is all steel. The rollers were badly machined and eccentric as are the gears. The bearing blocks are steel with no bearings so steel on steel with no grease nipples. The main plate will flex badly even on 1.2mm aluminium sheet as it is 3/8” thick from memory.
    A friend bought one made from 3/4” plate (might be Stakesys) and that worked well out of the box and even better with a few
    modifications, wasn’t a great deal more cost wise either. Best mod he did was using an office chair foot ring as a handle much like the steering wheels people fit.
  16. willie.macleod
    57
    Can't see any on ebay for £129?
    Anyway, this thread has been responsible for me spending more money. Ordered this one - comes with the stand but only 6 sets of dies (some of these cheap ones appear to come with a 7th shearing set).
  17. stuvy
    stuvy Member
    I’m after a pair of Louvre dies for my metz one, is there any cheaper alternative than the £50 eBay ones?
    jph likes this.
  18. 500e
    4,164
    SWest UK
    Interesting @Wallace I thought some of them looked a thicker frame For extra few £ might as well start with a thicker item
    Don't know if this one is thicker but has grease nipples, looking at the rear view of the formers there may be bushes as well, I do see they cant bolt handle on in correct orientation.
    None of the yout-tube mods mention different thickness frames :dontknow:
    https://www.amazon.co.uk/FlowerW-Sw...=1&keywords=bead+roller&qid=1584739129&sr=8-7
  19. Wallace
    Wallace Member
    6,659
    I just had a reply about about my friends one, it was not a Stakesys roller but one of the WNS range and he says it is 25mm not 19mm plate on the frame. Knowing what I do now about mine the WNS ones seem good value.
    Dcal and stuvy like this.
  20. Snowy90
    Snowy90 Member
    114
    Poor Part of Surrey
Advertisements
