R Robfpvgt New Member Messages 7 Location Perth Sep 21, 2018 #1 so I’ve got some rust holes all behind the sill where the body mounts are, I was gonna try cut it away or can I use rust converter and put a new price of sheet there..
R Robfpvgt New Member Messages 7 Location Perth Sep 21, 2018 #2 Or I could try undo the body mounts and lift it up to get some better room
pedrobedro Man at Matalan Messages 12,750 Location CX near Chesterfield Sep 21, 2018 #3 Lift it and get cutting back to good metal.
steviec_lj Rust Welding Professional Messages 2,806 Location Barnetby, N.Lincs Sep 21, 2018 #4 As above, get it off the body mount, and cut back to good steel, then glue some more in, and the body mount too. Playing over it just hides it, and it comes back, it doesn’t matter how well you treat the area either.
R Robfpvgt New Member Messages 7 Location Perth Sep 23, 2018 #5 steviec_lj said: As above, get it off the body mount, and cut back to good steel, then glue some more in, and the body mount too. Playing over it just hides it, and it comes back, it doesn’t matter how well you treat the area either. Click to expand... Sweet as. When you say glue do you mean like a rtv silicone glue or like jb weld epoxy style ? Rob
Shedendman Member Messages 5,201 Sep 23, 2018 #6 He means weld,thats a important structural area,as said cut the rot out and replace
angellonewolf Member Messages 8,115 Location bristol england Sep 23, 2018 #7 I assume he means weld not glue poss auto correct on the phone ?
G gt6s pre-moderated Messages 979 Location Newtownards Co Down Northern Ireland Sep 23, 2018 #8 Glue. He is using it as a slang word for weld. I use it too. Can you cut that outrigger off, repair then weld the outrigger back on ? Laurence
morssdn Member Messages 352 Location Stirling, UK Sep 27, 2018 #9 Mig-glueing.co.uk could be up for a bit of cyber squatting
