long story but here goes, I bought a Parweld stick welder, always wanted to learn. Practicing on thicker stuff and I was sticking bits together.
Then came the thinner sheet, you can imagine how that turned out!!!!
A second hand gys 130 easymig came up so I bought it. Result, I was back sticking thinner bits together.
The kind of thing I’m doing with it is repairs on wood burners and flues, I also make a lot of brackets and bits to install fireplaces. A lot of older twinwall systems don’t have mesh in the guards. Some of the wall thickness is 0.8mm and I’ve been mig welding mesh in for a factory finish look. I started off riveting brackets on and wire locking the mesh, it wasn’t quite the look I was after. It’s generally 316 stainless, the mesh is 1.6mm.
I wanted to change the torch on the gys but it’s fixed, that got me thinking. My first experience of mig is this little inverter, it’s done me proud but would a transformer based welder give me a more constant spot weld rather than the electronic help on the inverters? Most of the time that’s all I do, tack stuff together.
The bottom end is 30a and the way I’ve managed the thin stuff is concentrate the heat on the mesh and use a wet rag behind the bit I’m sticking it to.
The question is would I find a notable difference in say an Oxford transformer for this kind of stuff compared to the gys?
I started with co2 but soon changed to hobbyweld, made a big difference for me.
I’m running on a standard plug in the garage, possibly could get a bigger circuit installed. Max im going to use it for is 5mm anything bigger I’ll blob it together with the stick.
