julianf
- devon, uk
So, as i have mentioned, im after a table saw.
Theyre normally 3ph, and i only have 1ph here.
This is an example of the saw im after -
https://www.ebay.co.uk/itm/Wadkin-10-AGS-table-saw/162934805302
The manual for the saw lists the motor variants in its parts list -
http://www.wadkin.com/uploads/files/Wadkin AGS (10 inch) Sawbench Manual & Parts List.pdf
(pg 14 of the pdf if anyone is that keen!)
Theyre listed as brook gryphon units, but there seems to be options for both foot and frame mounting. Also variaton between 2 and 3hp. 3-3.5krpm
To the question -
Now, if i acquire one of these saws, im thinking it must be simpler to swap out the motor, than to get an inverter? Assuming, of course, that the motor is some standard size / fitment. I assume i would have to drop to 2800prm and slightly adjust the pulley size if i wanted to maintain blade speed (ill probably have a different dia shaft on a 1ph replacement anyhow). If the original switch gear is present, i think it supports both 1ph and 3ph configurations.
Or i could buy an electronic solution. But i know very little about them, despite my searches.
What would you advise? Im just planning, trying to work out costing etc.
Thank you.
To the question -
Thank you.
