3D MIG printing....
  1. Crouchy121
    Crouchy121 New Member
    9
    England Worthing
    Well this is a sign of things to come. What are you thoughts? I saw something like this a couple of years ago but it was print welding some weird object.
    slim_boy_fat likes this.
  2. RonA
    RonA specialist in repairing sealed for life equipment
    1,296
    Stockton on Tees, UK
    I observed for the first time a 3D printer in action the other day.
    It was just one of the cheaper type using plastic filament. As I watched it, the thought came to me how like mig welding the filament coming out was & wondered if you could link a mig welder to a 3D printing rig. Your video shows that its perfectly feasible.
    RonA
  3. garethp Forum Supporter
    816
    sw scotland
    I cant figure out how to do a link to a YouTube video on my phone but if you do a search for 3d welded propeller there are some vid's of what looks to be a bronze propeller being made for a tug boat.
  4. Moose McAlpine
    Moose McAlpine Member
    359
    Watford Hertfordshire
    How about a 3D printed bridge?
    fixerupper, RonA, JLP and 1 other person like this.
  5. fizzy Forum Supporter
    4,369
    uk
    Quality not great.
    Most of the new systems use sintered metal - a powder melted by a laser.
  6. slim_boy_fat
    slim_boy_fat Forum Supporter
    Not as good as @selectedgrub's offerings. :vsad:
    Hood and selectedgrub like this.
  7. selectedgrub
    selectedgrub Member
    877
    New Zealand
    My software is so out dated :laughing:
    [​IMG]
  8. JLP
    JLP Member
    163
    Beds - UK
    I used to do this for a living, at Cranfield University, but with MIG (It's actually done with CMT, but same principal) and plasma on the Ti parts. Worked on some pretty awesome projects with the likes of Airbus, BAE, Bombardier, Lockheed, etc. Making A320 wing pylons was my last bit there, awesome work but does get a bit boring when its all set up right.
    Check this one out from autodesk, they started this back when it was still delcam and making the A320 pylons was part of the development process of the software they now use.
    [​IMG]
    Also made the (at the time) worlds largest 3D printed part, an aluminium wing spar
    [​IMG]
    outofthefire, RonA, DAPPH and 7 others like this.
  9. JLP
    JLP Member
    163
    Beds - UK
    That's Wire + Arc Additive Manufacturing, the walls are typically much smoother in the laser applications but they do have their draw backs too such as strength and time to produce. The parts are typically machined after deposition with WAAM, not so much with laser powder bed
    fizzy likes this.
  10. Tinbasherdan
    Tinbasherdan Bodger in chief
    4,425
    Bolton, England
    Watched a video on damen tugs “printing” a tug prop , that was hellishly impressive
    JLP likes this.
  11. Maker
    Maker nEw mEmBeR
    6,550
    Don't ask questions
    I'm always impressed by the fine detail that can be printed, this is a chain tensioner pulley made by CermaicSpeed for cyclists with more money than sense.
    It's actually made to show off what's possible with the technology though you really can buy it of you're so inclined. The whole thing has about a 1mm cavity inside it, it would be more or less impossible to produce with conventional subtractive machining methods. I believe it's used in medicine too to recreate damaged/missing pieces of bone. This is of course SLS not WAAM.
    JLP likes this.
  12. JLP
    JLP Member
    163
    Beds - UK
    Autodesk also did this one, believe it was for a tug
    [​IMG]
    Shox Dr and slim_boy_fat like this.
  13. DAPPH
    DAPPH Member
    1,650
    Near to Cross Hands Llanelli SouthWales GB
    I wonder ….. you could built the frame for a space station , actually build it on the moon or in outer space as transporting reels of wire must be cheaper than the volume of space taken up by tubes etc . As the volume taken up by reels of material & robots would eventually be far less volume than the earth made tubes & spars or should I keep my feet firmly on the ground?
    Can you weld in a very cold partial vacuum is the question I suppose ought to be asked first?
  14. armalites Member
    3,775
    Herefordshire
    I was chatting with a BAE guy at Fairford air show a couple of years back they were talking about printing titanium even then. They could print enclosed parts that would not be possible in normal manufacturing.
    Hopefuldave and RonA like this.
  15. RonA
    1,296
    If the inert gas in mig welding is to keep out oxygen, would have thought a vacuum would be great to weld in, no shielding gas req'd.
    RonA
  16. TechnicAl
    TechnicAl Member
    6,160
    Rotherham
    Electron Beam Welding is done under vacuum but Ive never heard of MIG
  17. Moose McAlpine
    359
    A friend of mine works in motorsport as an "additive manufacturing specialist" where they do all sorts of 3D printing. He says at his work they print the Renault F1 gearboxes from titanium.
  18. Maker
    Maker nEw mEmBeR
    6,550
    Don't ask questions
    When you (arc) weld in at atmosphere, the gas (Inert or not) is ionised and becomes conductive. As the pressure is reduced, approaching a perfect vacuum, the breakdown voltage increases so it's harder to ionise and form an arc, I don't think you'd get arc welding to work in space.
    The limiting factor with getting things into space is the weight anyway, a bigger rocket can be built to carry a bigger (Greater volume) satellite without a huge penalty but a heavier satellite needs a rocket with bigger engines, carrying much more fuel (And the increased weight of the fuel requires even more fuel to carry it, that's why most rockets are multistage and drop their heavy fuel tanks when they empty). The equipment and materials to manufacture a space craft would be an awful lot heavier than a space craft already manufactured on earth.
    JLP, Hopefuldave and fixerupper like this.
  19. Ali
    Ali Member
    156
    Cheshire
    Thisoldtony has had a crack at it:
  20. RonA
    1,296
    This makes for interesting reading.
    https://www.weldingschool.com/blog/welding/history-of-welding-in-space/
    RonA
    Maker likes this.
Advertisements
