Thank you to everyone for the help.
Got all my safety equipment together and fired up the mig.
Wire feed right in and out the gun, using flex core to start (small roll came
with the machine) have an S tank on order, going to run 75/25 using 0.23 wire.
Did a sloppy bead and found out how short the duty cycle is on this machine.
Should not be a problem as will be doing sheet metal patch panels on my truck-
a lot of tack welding and bump and grind.
Well should be cool by now, off to the garage for some more testing.
Craig
Craig
