brightspark
- yarm stockton on tees
there should have been a condensation trap fittedWe had our shower extractor fan trunking that went from a ceiling fan out through the attic and to a roof tile vent droop and it filled up with condensation so there was no air flow.
The first signs were that we suddenly had loads of condensation on the upstairs bedroom windows, but we didn't know what the actual cause was. We only discovered the real cause some months later when water started dripping out of the fan inlet above the shower
When we emptied the water and re routed the trunking everything has been fine since, so it may be worth checking that any extraction you have is working correctly, even if not in the same room as the condensation.
