Thanks. Will do, I’ve just to figure out if it goes on f1 or F2. Do you know where f1 and F2 go? It’s between 7&8 on the new board.Yup, I'd stick a low value fuse in line with the phase conductor.
Ok thanks for explaining it for me. Hope this fixes it!X & XX are polarity sensitive and definitely need to be correctly connected, 7 & 8 are the sensing wires, as it's essentially a 'floating' AC voltage, the polarity is not important, all terminals 7 & 8 need to see is the potential difference between the output wires to control the level of excitation on X & XX. The fuse is there just to break the circuit (and power down the excitation output) in the event of a fault. It can be on the (nominally) 'neutral' side but it's good practice to put it on the 'phase' wire - none of which matters until a ground connection is introduced.
80v (DC??) across X & XX???Across x-xx I’m getting 80
Across L1-L2 I’m getting 130 which is about half of the output voltage at this rpm. I think the link is in the correct place. I didn’t move it. I’m not running anything external apart from this new board
