Is it an invisible lighthi does anyone think this light could be wire do a 3pin plug so it can be unplugged from sockets when not in use. Thanks
Is it an invisible light![]()
Yes no problemsThat’s the picture View attachment 205536
Just make sure you use a stuffing gland on it if you're dragging it about.
Should have one, it's ip65 ratedJust make sure you use a stuffing gland on it if you're dragging it about.
Just read the ad, pre wired 1.5 m cableIp65 until you knock the knockout out.
Did you get 30 or 60 watt ones.?https://www.ebay.co.uk/itm/272393442053
I've installed about 40 of the 6ft ones of those, only had 1 fail in about 4 years - pretty hard environment here for them too, very humid, some are open to the elements, some are in a freezer... really pleased with them, especially for the cost (they're on at least 12hours/day 7days a week)
if you buy any get the 'milky' cover, the clear cover sounds better but the LEDs are too bright, they blind you if you look at them
I put two 4ft ones up and both failed within about a year.... replaced them both and they've been ok since... I'm sticking with the 6ft ones now
electrically.... they're a bit cheap chinese, you get a flex with a plug on the end which plugs into the end of the light - there's a socked on each end of the light and you can get double ended wires to daisy chain the lights up together, I bought the long double ended wires, cut one end off and wired them into waggo junction boxes
That link you gave us offers both..I got 60 watt ones
I think there's a little cheeky/chinese ebay seller with those numbers, but it looks like everyone does the same thing with led power ratings anyway
