Windy Miller
Semi-Professional Potterer!
- North Kent, UK
https://engweld.co.uk/product/jei-p...rjn5gm30hNXqqHvAyw4-uxG_nxSxYqzQaAnf9EALw_wcB
These are the things....
That’s a proper bit of kit!
As a very very rough rule of thumb about £1/hole. When you work out the costs of CNC processing against doing it 'manually' plus factor in a CNC machine doesn't make errors, it costs more to do it the old way. The cost of the drill and saw lines is coming down so more stockholders are getting them which drives down the prices/rates they can command.
Factor in all the time in handling full bars, dealing with offcuts, logging cast numbers for offcuts, handling scrap, marking out, it really is the way to go.
Tea breaks, dinner, setting out etc it took about 2 min a hole but I wasn't constantly going straight after another as I had to lay it all out and make square etc. I was just wondering if it could be done quicker. My suppliers don't drill but they do cut only
As said above, find a supplier that does drilling and budget for £1 a hole.
Bear in mind if you can't give them a NC file, then they will charge extra to program .
If not then....
Mark out ALL the holes prior to drilling if possible. Then just follow through with the drill . If you have several groups of holes at the same pitch then make a template you can lay down on mark points and centre punch through. Drink tea when drilling.
Use these
Had 2 labourers drilling 22 dia holes in 20mm plate. They did 250 each and didn't snap one cutter . Use a good squirt of cutting fluid on each hole.
They're good those carbide cutters, hard spots don't seem to bother them like it does normal cutters. Worth the extra dosh if you're a regular user.
We have one like this only a lot older
A lot of structural steel comes in already cut, drilled, shot blasted and ready to fab. This is the sort of automation line that is used
I think the vid must be slowed down - i've seen the one at our stockholders and it moves at lightning speed.
If the holes are all marked out drilling 50 holes by magnetic drill is a couple of hours work.
I’ve seen small plasma and drilling centres but never anything like that!
Nothing like that in Essex. Rainham steel have a bozo with a roller and that’s about it.Our local stockholder runs a number of lines, one massive one in the middle with a huge blast/paint line, with rollers/ automated dollies moving and traversing the steel about literally as far as the eye can see. Its a 17acre site and expanding, must be an acre or two worth of rollers feeding machinery![]()
