HI Just bin reading the thread on 16amp power supply . I use my welders on normal 13amp is this ok . My arc welder is a sip wizarc 60-80amps My mig is a cem dual 120 . are these ok to work on a 13amp supply
cheers NEIL
If the fuse doesn't blow then you've got nothing to worry about, if it does blow then you only need to worry about fitting a new fuse, you won't harm anything else .
