No pedal with the Parweld though, so if you use one you will have to order that on top.So more people have the parweld ill have to se if the shop will order me one in the sell parweld but don't stock ther welders just gys Lincoln and jasic so we'll see the parweld is 400 cheaper
I don't think that the jasic comes with a pedal and I've managed up to now without one so its not a priority I know if they can get me a parweld that's what I'll probably be getting since it seems that more people have that one and its £400 cheaper than the jasicNo pedal with the Parweld though, so if you use one you will have to order that on top.
Mine came with a Parweld Pro26 torch with 3 button insert and a regulator.
I don't use a pedal so didn't matter to me.
Does thomas proctor in carlisle not do paraweldSo more people have the parweld ill have to se if the shop will order me one in the sell parweld but don't stock ther welders just gys Lincoln and jasic so we'll see the parweld is 400 cheaper
The jasic just has what's standard and I don't think it's a mini the weight on the spec sheet says its 25kgParwelds warranty is 6 years now, 3 years full and 3 years service programme with free labour.
That sounds a rather low price for the Parweld, I’d probably snatch their hand off at that.
Also.. that’s an exceptionally high price for the Jasic, check what they’re including and whether they’ve priced you on the mini model instead of the standard digital. The standard digital should be considerably less money.
The parweld is about that figure too.The jasic just has what's standard and I don't think it's a mini the weight on the spec sheet says its 25kg
If it is that weight then it is definitely not the mini, that weighs under 10Kg if I am remembering correctly.The jasic just has what's standard and I don't think it's a mini the weight on the spec sheet says its 25kg
The parweld seems to be the most liked on hearIf it is that weight then it is definitely not the mini, that weighs under 10Kg if I am remembering correctly.
