Blake's 7 Member Messages 205 Location Ireland Mar 17, 2018 #1 The box walls are only a few mm thick, What amps should I set my inverter to? I have a box of 3.2 mm diameter rods, are they OK to use or will I be better off with smaller diameter rods? Thanks.
gaz1 Member Messages 18,102 Location westyorkshire Mar 17, 2018 #2 id be using 2.5 but i can use 2.5s on any thickness with practice
A Arclikeharrypotter Member Messages 1,241 Location Northampton Mar 17, 2018 #3 Depending on what type of joint you are welding 3.2 would be fine. Just keep a nice short arc and don't attack it with masses of amps.
T TechnicAl Banned Messages 8,981 Location Rotherham Mar 17, 2018 #4 dia x 40 and you wont be far wrong...........2.5mm 100 amps.......3,2mm 130 amps
Blake's 7 Member Messages 205 Location Ireland Mar 18, 2018 #5 Thanks folks. I'm going to get a box of 2.5's and burn them at 100 amps.
Richard. Member Messages 18,347 Location Cambridgeshire Mar 18, 2018 #6 1Billion Amps said: Thanks folks. I'm going to get a box of 2.5's and burn them at 100 amps. Click to expand... Run them around 80 amps if it’s only a few mm thick. 100 amps is top end current for a 2.5
Blake's 7 Member Messages 205 Location Ireland Mar 18, 2018 #7 Richard. said: Run them around 80 amps if it’s only a few mm thick. 100 amps is top end current for a 2.5 Click to expand... Thanks for the advice. I will practice with the 2.5's on some scrap 2" x 2" box beforehand.
A Arclikeharrypotter Member Messages 1,241 Location Northampton Mar 18, 2018 #8 3.2 6013 at about 105 will do the job just fine. 2.5 at 100A you'l be blowing some holes, or getting undercut on 3mm box.
