jim painter
A couple of things,
Is epoxy (lechler 2k) ok to use on previously painted fibreglass (vw poptop), paint has been flatted and flackey bits sanded until solid and feathered. I havent gone through to the gelcoat only the primer.
Is epoxy to much, could I just use normal 2k primer, I was thinking epoxy would stick better.
If using the epoxy do I need to use normal primer on the epoxy, as I will be doing metallic base with clear, or can the base go straight over the top.
Thanks in advance
JIm
Thanks in advance
JIm
