Hi, can anyone advise please. I have never had the above machine going on TIG only on stick welding.
Before buying argon I thought i would try it to see if it was working.
Reading sequence of operation.
HF TIG and LIFT TIG
connect work lead
connect tig torch to neg terminal
set weld current
this next statement is my query
Connect remote control device, a remote control device is required for use during lift tig and hf tig operation.
Does this mean i will have to wire the trigger 2 pin socket on my torch somehow to the 8 pin socket on the machine before I will get anything to work.
At the moment no power is coming through the torch. I take it I can try it without gas, just to see if its working.
D EL
HF TIG and LIFT TIG
connect work lead
set weld current
D EL
