TheFabWorkShop
New Member
Hi Guys,
whats your review about those two welders:
Features:
Suitable for workshop use
Forced air cooling
Stable output by large capacity filter
Thermal protection with warning light
Gas test feature
Robust front and rear wheels
Accepts 5 or full 15kg wire reels
0.6-0.8mm welding wire diameter
Euro professional welding torch connector
Flux cored wire compatible
Made in the EU
Specifications for MIG 210 TURBO
Mains Connection 230/240V
Fuse 16A
Welding Current 30-190A
Voltage steps 6
Duty cycle 100%-65A
60%-95A
15%-190A
Welding wire diameter 0.6mm-0.8mm
Dimensions 780 x 354 x 560 mm
Weight 39 kg
OR
Specifications
Model No: esl2009 MIGHTYMIG210
Maximum Current: esl2009 210A
Wire Capacity: esl2009 5-15kg
Duty Cycle: esl2009 100% @ 80A, 60% @ 105A, 15% @ 210A
Cooling System: esl2009 Forced Air
Gas Type: esl2009 CO2, Argon, CO2/Argon Mix
Torch: esl2009 Euro Non-Live - BINZEL® MB15
Power Input: esl2009 230V - 1ph
Absorbed Power: esl2009 9kW
Case Size: esl2009 Large
Weight: esl2009 45.5kg
Gasless Consumables: esl2009
Flux Cored Wire (4.5kg x Ø0.9mm): esl2009 TG100/4
Replacement Tips 0.9mm (Pack of 5): esl2009 TG100/2
I think the Sealy is much better!!
Features:
Forced air cooling
Gas test feature
Made in the EU
Fuse 16A
Voltage steps 6
Duty cycle 100%-65A
60%-95A
15%-190A
Weight 39 kg
OR
Specifications
