Hi, had a good look around and was wondering if the above welder would be good enough for car fabrication i.e. suspension stuff, as I have begun designing some new suspension geometry for my rally car and would like to have a bash at fabbing it myself.
I have the Cebora version of the same machine and have fabbed a couple of trailers with it. One of them carries a vintage tractor OK so the welds are plenty strong enough. It will depend on the material thickness you are intending to use - others on here will have more knowledge than I do, but you should be OK at around 3mm. There is a calculator on the forum somewhere which will give you a good guide.
