Replacing MDF in garage racking
  1. Phil_D Member
    330
    Somerset
    ive acquired some cheapish garage racking that is in good nick except the MDF shelves are saggy and mouldy.
    Rather than replace this with more MDF what would be a better cost effective solution for use in a damp garage? Marine ply?
  2. the snooper
    the snooper getting older by the day
    19,811
    Hull UK
    A decent thickness exterior ply, it will be a lot cheaper then marine
    Gwil, brightspark and slim_boy_fat like this.
  3. Onoff Member
    375
    Sevenoaks, UK
    My garage isn't damp per se as it has a damp course but I do get a sheen of condensation on tool cabinets etc at certain times of the year.
    I had some scrap galv angle and made up shelves from 18mm chipboard flooring and roofing battens. A couple of coats of Wickes shed and fence paint and jobs a good 'un. Been done a good few years.
    (Not sure how the tree house got in there...)
    Jim Davey likes this.
  4. dobbslc
    dobbslc Forum Supporter
    2,922
    Hertfordshire UK
    I've got some thick old chipboard (3/4") on mine that's been fine for years, as long as it's not getting wet it'll be ok.
  5. p0689109 Member
    1,457
    stoke on trent,england
    Phenolic ply is the bees knees but expensive. There were some offcuts for sale on ebay the other day
  6. I use secondhand kitchen worktop.
    123hotchef and Johnseat like this.
  7. Dee J Member
    220
    Devon UK
    Shuttering ply from a builders merchant. Strong and reasonably water resistant (lasts many years outside in-treated).
    123hotchef likes this.
  8. Onoff Member
    375
    Sevenoaks, UK
    We know this as Buffalo board at work.
  9. slim_boy_fat
    slim_boy_fat Forum Supporter
    Helicopter? :dontknow: :D
  10. CompoSimmonite Member
    3,635
    Werrington, Stoke-on-Trent
    I use the (green) water resistant chipboard floor boarding
  11. 123hotchef Member
    4,998
    Kent
    I use whatever I have left over from projects for my shelves but my mdf ones have sagged ply or chip board gets my vote or osb
  12. Robotstar5
    Robotstar5 Casanunda Staff Member
    16,601
    Birmingham
    I've found chipboard sags/breaks up if used in outbuildings, garages etc. decent thickness plywood for me.
  13. Phil_D Member
    330
    Somerset
  14. Osb3 is better than shuttering ply, which will delaminate.
  15. CornishPete Member
    319
    Huddersfield
    ive used plywood pallets in the past from ebay. You can get one that's about 4' square for £2.50ish.
  16. gaz1
    gaz1 Member
    5,284
    westyorkshire
    ive used osb within a cool garage as better than using chipboard on other shelves used thick mdf instead but they aint touching the damp walls
  17. rcx132
    rcx132 Philip
    1,650
    London, UK
    Would full grain wood be affordable? That would last way longer. My brother used old pallet slats.
  18. Rocketman Member
    2,454
    England Leicestershire
    Decent plywood is actually more durable than most wood. Many pallets use pretty poor wood too.
  19. zzr1200
    zzr1200 Working at 650 ft on open steel work
    3,037
    Chesterfield, Derbyshire
    Extra secret storage a place to hide things from SWMBO.....:scared:
  20. Onoff Member
    375
    Sevenoaks, UK
    +1 if used "as is". I glued and screwed the tile battens on for rigidity and as someone else said used the V grade moisture resistant chipboard. Honestly its been sound.
Advertisements
