Removing machenery nameplates
  1. Spark plug
    Spark plug Forum Supporter
    2,826
    Durham, England
    ok so how do people remove and re-fit name and data plates from machenery, the ones held on with those little hammer in Rivet jobbies?
  2. grim_d
    grim_d Member
    958
    Scotland - Ayrshire
    Carefully.
    Check Keith Ruckers restoration/disassembly videos out on YouTube. He removes them frequently.
  3. MattF
    MattF Member
    8,516
    South Yorkshire, England
    What he said. :D If you're lucky, you can get to the holes from behind and punch them out. Rarely that lucky though. A thin scraper behind the plate sometimes works, but doing that you always risk damaging the plate. You can drill the heads too, but then you need to source new twist pins.
    Dieselkid 63 likes this.
  4. Robotstar5
    Robotstar5 Casanunda Staff Member
    16,601
    Birmingham
    Search for hammer drive rivets - example
    slim_boy_fat and ukracer like this.
  5. rikrobson
    rikrobson Member
    3,376
    Perth, Scotland
    it you put then in and out too much or don't take it carefully the hole can enlarge and then they dont stay in tight
  6. Shox Dr
    Shox Dr Chief Engineer to Carlos Fandango
    Pair of good quality pliers. Square on, and twist anti clockwise.
    You might mark the rivet but it will come out
  7. Spark plug
    2,826
    Durham, England
    I have managed to get two out by punching them so far from the back, with great difficulty at that. This won’t be possible for the others so ile try the pliers.
  8. R-D-R Forum Supporter
    299
    Derbyshire - England
    For the ones i have I used a Demel to slit the head and gently twisted with a screw driver. They reversed out a bit like screws.
  9. brewdexta
    brewdexta Forum Supporter
    3,215
    Yorkshire
    I tried pliers on the viceroy lathe I am renovating as I didn't do a complete nut and bolt restoration so couldn't get into some of the castings to push 'em out. This has worked for me before but the little tinkers wouldn't move on this on so I ended up just masking the plates off. Unfortunately, some of the paint pulled off the plates when I removed the masking tape so I would use card and blutack in future. Not too bad fortunately, better to take 'em off if you can.
  10. 8ob
    8ob Member
    1,976
    moscow on thames
    I have some of these rivets that came with a load of other stuff I bought, dont think I will ever have a use for them so if anyone needs some pm me an address and I will stick some in an envelope.
    [​IMG]
Advertisements
