Daveville30
- Ireland
Hi I've just ordered one of these.does anyone that has one have pictures of a few runs done with the mig?
I should be grand so.anyone made an adapter for 15kg spoolsTo be honest they would look no different to other runs, any mig set up and working correctly with an experienced user will lay good runs regardless of it's make.
I use cougar 5Double boost just watched them.it will handle what I need it for. Where u using argoshield heavy or light?
Hi David I know you posted this quite a few days ago but thought I'd reply .Hi I've just ordered one of these.does anyone that has one have pictures of a few runs done with the mig?
No m8 not had any probs been running off 13 amp so can't get the full beans if u know what I mean but the m/c has been bang onI'm just awaiting gas. Have wire ordered.im the same work as a welder just wanted something for at home.has it tripped the breaker on you?
Yes im hoping to upgrade supply to 16 amp and It was only 4-5 mm flat and probably 3 mm box section.I'm hooking it up to a 16 amp supply so should be able to weld full whack as long as the 20amp breaker doesn't trip. What kind of thickness where u welding with on the 13 amp
