Hi
Just a quick question regarding gas setting.
I am using hobby weld argon 5 mix and when I set regulator the same as johns video on line at just under 10 on gauge the needle vibrates and pulses. This stops at a higher setting but using a lot more gas is this correct? Not sure what it should be as it is not measured in psi but cuts/ welds and Ltr/min. Any idea what pressure should be when using the regulator supplied with r-tech 180?
