Good point! There's an escape hatch for the bolts at 6 o'clock, but getting set up at 11 and 5 should give more stability.Looks fine but I would birl it round so that the bolts are running along the X axis as that should provide more stability to the tool.
That is unusual as that is normally the 0 degree position for bolts on a compound but yes, 11 and 5 would be almost as goodGood point! There's an escape hatch for the bolts at 6 o'clock, but getting set up at 11 and 5 should give more stability.
It's taken me two weeks to make that irregular shaped block of aluminium!Lathes are meant to have swarf on them, shows there been used not polished.
As a project why dont you "make" the correct sized tool post....
Electronics and software, so I'll take thatIf your not from a machinist background you've done very well, If you have a machinist background you've done well.
Good man keep at it, I served my time in turbine manufacture machining so I'm fairly O K with workshop machinery but a 13 amp plug is about my limit when it comes to electrickery More strings to your bow.Electronics and software, so I'll take that
