Kent
- Bowland, Lanacshire,UK
Which is how most coil springs are done now. Beware if you burn them. Off for use as tool steel2k etch primer and 2 k topcoat
it depends on the humidity of the air on that particular day preferably do them as soon as possibleIf said parts have been sand blasted ,was allways told they need to have a coat of something on them in under 12hrs or else corrosion sets in , that came from a foreman working for an offshore contractor in a yard onshore.
Clearly these guys!That's cheap, who does anything for a tenner?
its ok outside with a decent maskNot setup for 2K sadly, Will consider in the future though!
Painting outdoors?!
How's your paint work look?
I sprayed the tinwear of my bsa in the doorway of my shed with a non-airfed mask (which the local paint suppliers said was fine to use with 2k). The finish was excellent, i surprised myself, no clouds of paint vapour in the air, and i did not have a problem.
Is it a bit like saying I walked across the motorway drunk and was just fine. Therefore it's safe?I sprayed the tinwear of my bsa in the doorway of my shed with a non-airfed mask (which the local paint suppliers said was fine to use with 2k). The finish was excellent, i surprised myself, no clouds of paint vapour in the air, and i did not have a problem.
it looks great thanks .I spray inside a warm garage with a decent mask but not air fed . but I wouldn't advise it to anyone elsePainting outdoors?!
Raptor bed liner for me did my torsion bars with it as well as a few other 4x4 parts and it has lasted well
Is that an epoxy type paint ?
