Bryan Williams
- Manchester England
I have to remove an outdoor wall tap today ,the stopcock is below this,, I will shut that, open the outside tap to drain..in th
ie pic you can see the pipe on the left going through the outside wall,my idea is to replace the tee fitting on the upstairs feed on the right with the valve fitting on the horizontal pipe, doing away with the outside horizontal pipe completely.
Am I likely to run into problems replacing the valve like needing new olives or is it just a straight swap?
Cheers.
Cheers.
