Hello,
I received my OxyTurbo kit this morning but after I screwed the oxygen regulator on the bottle, the needle reads 100 even though I hadn't opened the valve. If I open the valve, the needle position does not change. Conversely the fuel valve doesn't read anything when screwed on to the bottle but the needle does move when the valve is opened.
Should the oxygen reducer do this? I would have thought the behavior of the two valves would be the same?
Thanks
Thanks
