mark501w New Member Messages 21 Location socal usa Aug 31, 2016 #1 Got a old thermal dynamics cutmaster 50 running new consumables 90 psi starts fine but won't cut through 1/8" angle . Looks like a scarf cut?
Wendelspanswick Member Messages 6,487 Aug 31, 2016 #2 mark501w said: Got a old thermal dynamics cutmaster 50 running new consumables 90 psi starts fine but won't cut through 1/8" angle . Looks like a scarf cut? Click to expand... 90 psi sounds high to me, 55-60psi is more of a ballpark figure for a plasma.
gaz1 Member Messages 18,003 Location westyorkshire Sep 1, 2016 #5 simple thing but check for air leaks within your system that air should blast through the nozzle and be audiable also try it through thinner material and see if it cuts them could be an electrical problem so not enough amps to do the required job
mark501w New Member Messages 21 Location socal usa Sep 1, 2016 #6 It's pushing air, I'll try some sheet
1 123hotchef Member Messages 13,885 Location Kent Sep 1, 2016 #8 i find my cut 50 cuts better when the psi is turned down a bit
mark501w New Member Messages 21 Location socal usa Sep 1, 2016 #9 Down loaded the guide did the basics . New tip, checked for oil, no liquid. checked input voltage,220v. Just won't cut 1/8".
mark501w New Member Messages 21 Location socal usa Sep 1, 2016 #10 Cuts .060 stainless sheet no problem . .140 mild steel leaves a nice scarfing groove. I think think the amp selector is goobered up.
gaz1 Member Messages 18,003 Location westyorkshire Sep 1, 2016 #11 heres the instruction manual for it http://victortechnologies.com/IM_Up...er 50 Operating Manual_(0-2805)_April2003.pdf
mark501w New Member Messages 21 Location socal usa Sep 2, 2016 #12 Thanx got it , it's something odd. I took it over to J&J's in Ontario He's familiar with Thermo Dynamics. It's like the amperage isn't comeing up.
mark501w New Member Messages 21 Location socal usa Sep 20, 2016 #13 One of the igbt' is bad . Victor is giving 12$ a amp on trade ins picked up a cutmaster 42 sent in the poop sheet see what happens
