hotponyshoes
- Somerset. Uk
I wonder if wire cost is in similar proportion to gas (pennies)...?
Probably.
It sounds like you are teaching students or something though?
If that's the case then I would expect each fillet to be slightly different plus they will be getting false/missed starts etc so they are not going to use the same amount of wire on each weld anyway.
And I don't expect you will get a set of scales that can weigh a 15kg spool accurately enough for that without spending several years worth of wire on them.
If you count the length of wire used remember to account for the 3m (or whatever length the torches are) that will be unusable at the end of the roll.
For what you are doing, trying to work out the actual cost-per-weld seems pointless.
It might be better to monitor the overall use over a week/month and then divide by something useable like the number of students trained or number of sessions run or something.
I would think you would want to allocate the costs against something you can charge for as I'm guessing you will charge them a fee per session or course or something.
Not give them an invoice at the end for
4hrs of training @ £85/hr
122xfillets @ £0.02
Total £ 342.44
If you do need this data for some other reason then have a look at some of the industrial machines. You are unlikely to find much info in consumer brochures so you might need to try and get a rep to visit or get through to one of the installation guys.
Some of these welders have terminals that output data telling you exactly how much wire was deposited on each individual weld. They also constantly monitor the power input of the weld so from that you could probably work out the actual electrical consumption pretty well.
Even then, a welder might use slightly less power on the first few runs and then start using a bit more when it warms up and the cooling fan kicks in.
Again, to be precise in electrical usage you would need to plot it against the weather as the fan might run less in the winter than the middle of summer!
If you have the luxury of a temperature controlled air-conditioned workshop then you will need to take into account the extra costs of the a/c running harder when a welder is chucking out heat!!!
