angellonewolf
- bristol england
This string of 4 worded obsenitiys please fill in as required mini moto got it was not running after a carb clean run as sweet as a nut for 2 or 3 goes 3 rd time out played up a little chugging a little not miss firing but bogging down a little when throttle pulled but now as soon as it runs for 1min and get hot as soon as you pull the throttle it dies
Starts near first time and tick over is fine there is only one screw on it and I believe that adjusts the tick over on the carb
I took the carb apart quickly and found the float had fuel in it so bought a new one fitted that seamed to fix it but son had a go in the garden for a min or so and same thing happened again
The only thing I can't remember if we had this problem the only thing I done more recently was took the fuel on off tap apart I believe it all went back together fine but can't remember if it was the cause or just one of those things
